10-12-2020 14:24
10-12-2020 14:24
I have not got the wrist or clip option on my inspire 2 or the water lock option
Best Answer01-29-2022 17:09
01-29-2022 17:09
Press and hold both buttons on the sides of the device. You'll get a list of settings. Swipe up until you get to the last one. That's the setting for "On Wrist" or"On Clip". Tap on that, if you need to change it.
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
10-12-2020 18:55
10-12-2020 18:55
Same. Where is it?!!
Best Answer10-12-2020 20:16
10-12-2020 20:16
So we just had a horrible two days trying to make the brand new Inspire 2 register activity and sleep. Turns out there are two software switches on the Fitbit itself. You must turn HR on And turn the “on clip” to “on wrist”. You cannot do this in the I phone app—it is only hidden on the Fitbit itself. Tried calling Fitbit’s help number—they were disappointingly useless—they hadn’t a clue. Only one other post in this forum got me to looking much harder.
Best Answer10-13-2020 06:25
10-13-2020 06:25
Hi
Did u eventually find the clip/wrist function, if so can u tell me where it is please
Best Answer10-13-2020 07:21
10-13-2020 07:21
Hi @Ang1 see Page 12 of the user manual - click to go there.
10-13-2020 11:34
10-13-2020 11:34
Thankyou working now
02-12-2021 16:00
02-12-2021 16:00
In the exercise tab is the sub menu where you can find the clip to wrist option.
Best Answer01-29-2022 16:56
01-29-2022 16:56
I have looked through Exercise and swiped every which way, but I still don't see a setting for the clip/wrist function. Where is it, exactly?
01-29-2022 17:09
01-30-2022 12:34
01-30-2022 12:34
08-26-2022 10:51
08-26-2022 10:51
I don't get how this was solved. This option is literally not there for me. I've scrolled up and down. I get that part, but there is no "on wrist" or "on clip" option, not in the first menu, not in the settings menu. I checked to see if the Fitbit Inspire 2 needed an update and, at least as of last night, it did not. I'm wearing it anyway (on my pocket) and it appears to be counting steps OK. I don't know if this is a feature they've removed, or if I'll eventually see it if the Fitbit updates or what. I've seen many other posts with people who couldn't find it either but it's never explained how suddenly they did find it!
Best Answer08-27-2022 03:37 - edited 08-27-2022 03:39
@bookthief This YouTube video shows you how to get to this setting. The On Wrist/On Clip feature is part of the basic programming and shouldn't need an update to get it.
Laurie | Maryland
09-16-2022 19:21
09-16-2022 19:21
Thank you! Problem solved!🙏😎
