No green lights on Inspire HR
I charged my Fit Bit inspire HR last night and now it won’t vibrate with notifications, there is no green light and won’t track my steps or heart rate. It will say it syncs and will give me notifications but nothing else.
5 REPLIES 5
Nice to see that you're digging into the Fitbit Forums @Les_03, let me give you a warm welcome to our community.
Thank you for reporting the issues with your Fitbit Inspire HR. I'd suggest to try these steps: Why don't I see my heart rate on my Fitbit device?
You can also restart your Fitbit and check the steps here: Why are notifications delayed or missing?
I'll be around in case that you need anything else.
And it's off completely I did everything and nothing works what I can do ?
I tired everything but still doesn’t work.
The watch is still under warranty and I would like to replace it.
Hi. Im having the same issue with the green light and sensors not working but my screen has started acting beyond odd. Its swiping when im not touching, refusing to swipe when I try, getting stuck between screens scrolls. Ive been going through forums all day and done all the troubleshooting (reset, unpair, delete, repair) all I can find. I cannot get the screen to work at all unless its charging, thats the only way I could manage to get it reset. I would greatly appreciate any help! Thanks!
If it is under the warranty, call Fitbit support and they will help you out!
I called them and they were shipped replacement.
