01-07-2025
08:51
06:11
FatimaFitbit
01-07-2025
08:51
06:11
FatimaFitbit
I have turned on imessage notifications on my inspire 2 but no notifications are coming through.
certain other apps are though??
Please help...
Moderator edit - updated subject for clarity
Best Answer01-08-2025 06:15
01-08-2025 06:15
Hi there @WalkingFriend! A warm welcome to the Fitbit Community!
Thank you so much for informing us about this situation.
Have you already checked if you have the "do not disturb-" or "sleep mode" activated? Please try to sync your Inspire 2 with the Fitbit app too.
I suggest you follow all the instructions described here: Why are notifications delayed or missing?
Best Answer01-08-2025 10:05
01-08-2025 10:05
Thank you @FatimaFitbit I have solved the problem.... I had previews on never....
I'll try it now! Hopefully it works!
Thanks for all the help, I'll definitely ask again as I am not the best on electronics so another problem will definitely arise!
01-08-2025 13:21
01-08-2025 13:21
Hi @WalkingFriend!
Thank you so much for your answer.
That's very good news that you could solve the problem, thanks for your efforts too.
Yes please, the Fitbit Community is always available to you. We'll be happy to help.
12:31
10:39
ManuFitbit
01-11-2025
12:31
10:39
ManuFitbit
I’ve tried all of the steps recommended but I’m still not getting any type of notifications on my Inspire 2. All the settings on my iPhone and Fitbit appear to be correct I can’t find anywhere in the Fitbit app to enable vibration either. It’s always worked perfectly until just recently. I’m at a loss as to how to fix this issue. Hoping you can help. Thanks
Do not disturb and sleep mode are not activated on my phone. Is there a way they would be activated on the Fitbit itself? This only started happening after I upgraded to Fitbit Premium. Thanks
Best Answer01-13-2025 10:29
01-13-2025 10:29
Hi! Yes.
On an Fitbit Inspire 2 (and mabe more I don't know):
Press the side 'buttons' until it vibrates. Then it will come up with the quick settings:
Scroll down until you see DND - do no disturb - and Sleep mode . Make sure these are turned off
01-13-2025 11:19
01-13-2025 11:19
