07-11-2022
05:52
22:17
07-11-2022
05:52
22:17
Hi there
The screen on my Inspire 2 has gone black, there are no flashing lights on the back and the buttons do not respond even when I try to reboot it.
Has it died? And if so, how do I go about getting a replacement?
Thanks
07-18-2022 15:32
07-18-2022 15:32
Hi everyone.
Welcome to the Community Forums. Thanks for sharing the details about the issue with your Inspire 2. I really appreciate the time that some of you have taken to stay in contact with our team.
If you haven't done so yet, I recommend following the tips and recommendations provided here Why isn't my Fitbit device's battery charging? In case this is not working for you, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Hope that helps.
Best Answer07-13-2022 03:56
07-13-2022 03:56
I’m having the same issue but I haven’t tried rebooting yet. How do I do that?
Best Answer07-16-2022 07:31
07-16-2022 07:31
They say to plus it into a usb and hold the buttons in for 5 seconds. It doesn't work for me though!
Best Answer07-16-2022 17:43
07-16-2022 17:43
That doesn't work for me either. What to do next. I haven't used mine for a while
Best Answer07-16-2022 17:45
07-16-2022 17:45
I just plugged mine into the usb port on my pc and it started up.
Best Answer07-18-2022 08:34
07-18-2022 08:34
I have the same problem. I run out of battery last week and then it stopped working.
Have tried all suggestions on line, none works.
I believe the device is in some "sleep mode", just need a way to wake it up. Even reboot (holding down buttons for over 30 sec while plugged to USB charger) does not work. Have tried with multiple USB charges and cables. My wife's Inspire works just fine with the same USB cable.
Any suggestions?
I even managed to disassemble it, but still not able to find any way to "wake" it up.
Best Answer07-18-2022 11:22
07-18-2022 11:22
I am having the same issue. States the battery is at about 50%
07-18-2022 15:32
07-18-2022 15:32
Hi everyone.
Hope that helps.
