08-13-2022
18:28
22:11
08-13-2022
18:28
22:11
Using an iPhone, and I've read you can change the water goal using the "gear" icon in the upper right side of the water tile. However, I have no gear icon! Is there an alternate way to change the water goal from the iPhone app???
08-13-2022 20:27
08-13-2022 20:27
fitbit.com and go to your dashboard settings - you try that yet?
Best Answer08-13-2022 20:27
08-13-2022 20:27
Best Answer08-13-2022 21:20
08-13-2022 21:20
Thank you!!! I had spent quite a bit of time at fitbit.com to try and find the setting and was uncessful. After reading your answer, I went and looked AGAIN... and after accidentally hovering over the tile for some time with my cursor, the gear showed up and I was able to change it. Lol! Thanks for getting me to check again; I appreciate it.
08-13-2022 21:46
08-13-2022 21:46
Glad you didn't give up @ToniaTau !
