05-10-2022 14:57
05-10-2022 14:57
I got my Fitbit Inspire 2 about a month ago and it worked well for about a week. Since then it tracks sleep on occasion and it no longer displays texts or alerts phone calls. It also stopped reminding me to get active. I've reset it numerous times. I think this is my first and last time with a fitbit product.
05-10-2022 15:50
05-10-2022 15:50
Hello @ReenaD7
Is it possible that you have your DND (Do Not Disturb) and/or your sleep mode turned on your Inspire 2? You might have gotten turned on by accident. If you have either of them on you will not receive the notifications you are describing as not getting. Look here to make sure your notifications are set correctly:https://help.fitbit.com/articles/en_US/Help_article/1979.htm
As far as sleep tracking look here to find tips to help you track this: https://help.fitbit.com/articles/en_US/Help_article/1314.htm More sleep tracking tips and information can be found here:https://help.fitbit.com/articles/en_US/Help_article/2163.htm
😃 please let me know if this did indeed answer your question and your getting notifications again
Best Answer05-10-2022 17:42
05-10-2022 17:42
Hi,
I've already read through these ideas and tried them. It isn't on DND and doesn't have sleep goal set. Everything worked fine at first then just stopped. It's pretty frustrating.
Best Answer05-10-2022 17:50
05-10-2022 17:50
Hello again @ReenaD7
I’m sure it’s very frustrating. I’d be frustrated as well. Have you tried restarting your Inspire 2? You won’t lose any data doing so. Just press the button on the side of your Inspire 2 and hold it down until you see either a smiley face or the Fitbit Logo then release the button. You’ll feel it vibrate indicating it has restarted.
😃 Keep me posted on how it goes
Best Answer05-11-2022 05:20
05-11-2022 05:20
Hi,
Thanks for getting back to me. I've done that multiple times. The first time it seemed to help for a few days. Then it happened again and hasn't come back.
Best Answer05-11-2022 07:30
05-11-2022 07:30
If you haven’t made any setting changes and you restarted your Inspire 2 then I think your best best is to contact Fitbit Customer Service: https://myhelp.fitbit.com/s/support?language=en_US. I find calling them directly or live chat as the best option.
As a last ditch effort can you just peek at these settings: open your Fitbit App, tap profile picture, scroll down and tap Inspire 2 then scroll down and tap notifications. Ensure all your notifications are indeed enabled there. Now tap App Notifications and make sure things you want are enabled there as well. Also check these as well:
Lastly, on your iPhone settings- Notifications- Messages and set Show Previews to Always
I’m hopeful that a settings tweak will help otherwise I would call Fitbit Customer Service as I described above.
😃 Please let me know how it goes
Best Answer05-11-2022 07:42
05-11-2022 07:42
Thanks for these tips. I have an android, but think I've checked everything. I will try customer service. Thanks for all your help.
05-11-2022 07:47
05-11-2022 07:47
I’m sorry i was unable to help. Hopefully Fitbit Customer Service can get you back up and running. 😃 Please let me know how it goes. The help you get there might help others here. Good luck to you.
