09-15-2024
16:40
10:16
ManuFitbit
09-15-2024
16:40
10:16
ManuFitbit
I've found posts with directions to reset your device and app connection. I've done all of that.
The last date on which I have complete sleep data is 2 Sep 2024. I can also see that I have no heart rate nor other health metrics since that time as well.
There have been no changes to the device as far as I know and it's on the same hand at the same tightness. How can I check to see what, if anything, is different that would prevent this data from being recorded. I assume, because of this, the Exercise count and active zone minutes are at 0.
My step data is the only thing that is complete.
Moderator edit: clarified subject.
09-18-2024 10:01 - edited 09-18-2024 10:14
Welcome to the forums @PhilC_Boston.
Thank you for sharing the details regarding this kind of difficulty that you are experiencing.
I'm not sure if you are still having this situation with sleep.
Please confirm that you are not using 'Clip Mode'. To check this, press and hold both buttons on the sides of the Inspire 2. You'll get a list of settings. Swipe up until you get to the last one. It should say "On Wrist", if you want see your heart rate. If it says "On Clip", tap on that and change it to "On Wrist".
In addition, it's important to review heart rate:
Also, for more detailed information, see: What factors can affect my heart-rate reading on my Fitbit device?. Keep in mind that if your heart rate is OFF, you won't get sleep stages as heart rate readings are key for your sleep details.
In addition to that, I suggest taking a look at this help article Why don't I see sleep stages today?
Best Answer09-19-2024 05:00
09-19-2024 05:00
That might be it. I’ll reply after sleeping tonight to confirm.
