06-02-2019 17:53
06-02-2019 17:53
Switched from a Fitbit Alta to to Fitbit Inspire HR. I ran the setup and it was complete. It is not showing any of my information. My daily progress like footsteps or place for my water consumption. Is it the same format or is it a different set up? It will allow me to enter my water consumption, but my footsteps per day are not being recorded like with the Fitbit Alta. It was so easy and very understandable with the Alta's format. Please help I am so confused. Not very computer savy.
Best Answer06-02-2019 18:08
06-02-2019 18:08
Is it on the tracker or on the app that you not seeing any step count?
If not seeing on the tracker, do you see where steps would be displayed? Does it show zero, or blank, or dashes, or something else?
You say it is not showing any of your information. Is there any display at all on the tracker? If so, what is it showing and what it is missing?
Best Answer06-02-2019 18:24
06-02-2019 18:24
Best Answer06-02-2019 19:31
06-02-2019 19:31
If it looks right on your tracker, it sounds like it is not syncing. Check last time synced to see if it was recent.
