Not receiving text or phone notifications on Inspire HR
Just purchased the inspire HR and can not receive messages or phone call notifications my partner has the same and both installed on the same day but mine will not work 😳
2 REPLIES 2
Same here - mine stopped notifying me of emails and text messages.
@Klingy @boobear1947 Welcome! It's great to see you around!
Let me help you with your missing notifications on your Inspire HR. Which phone are you using? Is it compatibleYou can try refreshing the link between your phone and your tracker by doing the following:
  • Go to your phone's bluetooth settings and remove all devices listed there.
  • Restart your phone and restart your device
  • Check that no battery saving app/feature on your phone is affecting your Fitbit app.
  • Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
  • You can find troubleshooting instructions here.
Let me know how it goes.
Alvaro | Community Moderator
