Notifications display - Inspire and Inspire HR
ANSWERED
I just switched from Alta to Inspire HR and frankly, the Notifications screen is pretty useless the type is so small. There needs to be a setting where the display can be changed to scroll from bottom to top like the Alta's - allowing a little more time to read the notification as it scrolls and slightly larger (or maybe it looks larger because it is not so crowed) font. Thank you.
1 BEST ANSWER
Accepted Solutions
Hello @Zannie, it's good to see you around in the Community forums.
Thank you for your inquiry, at the moment it's not possible to change the settings of the display in the way you mentioned, but I do recommend that you post this specific idea in the Feature Suggestion board of the Community, this section is constantly reviewed by the team of developers for possible updates in the future.
You can also for this idea about having more settings for stat display, since it's also related to the option of having more options available for the Inspire HR display.
1 REPLY 1
