08-22-2022
08:31
21:01
08-22-2022
08:31
21:01
How do I amend the standard number of steps per mile on my Inspire 2. Being a small person I do more steps per mile that the average person.
08-22-2022 14:40
08-22-2022 14:40
@c8rolyn I looked at your profile and see that you joined Fitbit in 2016. If you used the default setting with your previous Fitbit(s), then there is no reason to change your stride length with your Inspire 2. Fitbit estimates your average stride length. But you don't travel that distance every time you go up and down stairs. Your stride length will change with walking speed. It will be shorter when you are walking 4 mph than 3 mph. It will be shorter when you walk up a steep hill. In short, if you have normal body mechanics for your height, there's no need to adjust your stride length.
If you choose to measure your stride length using a step count and measured distance, then you definitely don't want to do it in 20 steps or all on a flat surface. You need to use a longer distance, go up and down hills, and vary your speed. Chances are, you will come up with Fitbit's estimate.
Laurie | Maryland
08-22-2022 08:45
08-22-2022 08:45
Hello @c8rolyn
You can adjust your stride length. Here’s an awesome how to video: https://m.youtube.com/watch?v=NwGsOyNEcak
😃 Please let me know if this provided you the answer you were looking for.
08-22-2022 12:30
08-22-2022 12:30
Agree with answer by @SunsetRunner , but also be aware that Fitbit takes into account your personal data (height, sex, age, etc) in setting your default stride length, so it might not necessarily be off as much as you expect just because you are a small person.
08-22-2022 14:40
08-22-2022 14:40
Laurie | Maryland
