06-20-2025 02:02
06-20-2025 02:02
I’m reaching out because I’ve been experiencing ongoing issues with the screen brightness on several replacement units of the Fitbit Inspire 2.
Despite trying all the recommended settings — sleep mode, screen brightness, syncing, firmware updates, and different clock faces — the display remains extremely dim and nearly unreadable. I’ve compared it directly with a family member’s Inspire 2, and the difference is significant. Mine is far too dark to use comfortably.
I’ve returned the device three times under warranty, followed all the required steps, and even submitted a video to demonstrate the issue. Unfortunately, the problem remains unresolved.
Meanwhile, my Premium subscription continues, even though I’ve been without a usable device since March 2025.
I would really appreciate a permanent solution to this problem or an alternative option, as this situation has been going on for several months now.
06-20-2025 09:12
06-20-2025 09:12
Hi @patriciastr. This is a user to user help site, not Support. No one here can help you. Please contact Support for more help.
I also want to point out that Premium is part of your account, not tied to a device. It has extra features and additional insights. Sadly, it continues whether your device is working or not. I hope you get a resolution soon.
Laurie | Maryland
Best Answer06-22-2025 16:08
06-22-2025 16:08
I have the same problem with my Fitbit Inspire 2 while my husband's slightly newer Fitbit Inspire 2 doesn't have this problem.
I reset and checked that the Fitbit is not set on dark but that hasn't helped.
My Fitbit is 4 years old, so I wonder if it's just worn out.
