Peak heart rate not showing on Inspire HR
My Inspire HR does not register the correct peak heartrate.
During high intensity interval training actual heartrate went up to 160, however my Inspire HR registers only peaks up to 115.
Anybody any suggestions?
2 REPLIES 2
@JJdeP, welcome! It's great to see you around!
Let me help you with your peak heart rate detection. I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Let me know how it goes.
Alvaro | Community Moderator
Hi Alvaro,
Thanks for the tips.
I followed your advice and we have partial succes.
During my recent HIIT training the Fitbit registered one peak moment above 150.
However there should have been 15 peaks above 150, so it looks like there is still a registration problem.
Do you have any other advice?
I also followed the tips on your site.
Kind regards
