Problem with my notification on my inpire HR
My problem regards to notification on the app
When i set the notification on the Fitbit app i see this message pop up
"Notification service not running. A phone restart is required to re-enable notification on your tracker."
I'm using an Android phone.
i tried to do the above but it didn't work, what can i do
1 REPLY 1
@Aiotex, it's great to see that you've visited the Fitbit Community!
Let me help you with your Inspire HR not getting notifications. Which phone are you using? Is it compatibleYou can try the following:
  • Go to your phone's bluetooth settings and remove all devices listed there.
  • Restart your phone and restart your device
  • Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
  • You can find additional suggestions here.
Let me know how it goes.
Alvaro | Community Moderator
