07-28-2019 00:58
07-28-2019 00:58
My InspireHR consistently does not turn on when I raise my arm, no matter how I raise it. I work in a hospital and really rely on the clock, so it’s annoying af not be able to use this feature. Must I wear two watches on arm ? Le sigh..
Best Answer07-28-2019 06:10
07-28-2019 06:10
Hold in left side button for a few seconds. Turn on the screen wake (light bulb). It worked for me.
07-28-2019 06:10
07-28-2019 06:10
07-28-2019 14:03
07-28-2019 14:03
Best Answer07-29-2019 08:07
07-29-2019 08:07
I am having the same trouble. When my Fitbit arrived it showed the time when I raised my wrist, now it's stopped. Unless I use the side button I can't see the time, very annoying. I upgraded from and Alta HR for swimming but this one isn't much use as a watch.
07-29-2019 09:07
07-29-2019 09:07
Thank you!!! I apparently managed to turn mine off when putting a new band on, and could not find how to turn it back on. This also solved my "how do you see your battery level??" problem - there it is!
07-29-2019 09:09 - edited 07-29-2019 09:10
You have to hold the button down for a couple of seconds and then tap the screen wake icon. I love my Inspire, but the controls aren't very intuitive!
07-30-2019 08:51
07-30-2019 08:51
many thanks!
Best Answer07-30-2019 09:31
07-30-2019 09:31
same with me too, i held the left button for few seconds, no response
07-30-2019 09:49
07-30-2019 09:49
Thank thank also thank youuuuu!
07-31-2019 04:15
07-31-2019 04:15
All fixed now, the trick is to hold the button in rather than just press it, then press the lightbulb. Seems like this needs doing every time i change the strap. Would be helpful if this solution was in the FAQ’s
Best Answer09-29-2019 14:01
09-29-2019 14:01
THANK YOU!!!!!!!! I hate raise to wake.
Best Answer10-03-2019 14:04
10-03-2019 14:04
Ah, thank you! I had this issue too.
Now I also know how to avoid the lightning up during the night as well. The menu where you could dim the screen wasnt effective enough *though I think this is how or when I disabled the wrist tilt I guess...).
I dont mind about the light, but others do....
