07-09-2022
01:33
22:17
07-09-2022
01:33
22:17
I’m having the same problem. I bought my Inspire 2 on the basis of a good review back in April and have had almost 4 months of constant frustrations. I have overcome the dim screen I think and finally via the forums have figured out why is suddenly stopped monitoring my heart rate but I have the same problem as you.
I wear glasses but not when I run and I can just about get my Fitbit set up before I leave my house so that it’s paused and I just have to tap after I have done my warm up walk HOWEVER when I have finished my run, I haven’t yet after running 3 times a week for 3 months managed to get it to end and finish. I loose it every time. The screen is difficult to see and my hands are hot and sweaty, is that the problem?
I like you am reaching for the rolling pin, it should surely be easier than this. I had a Fitbit charge and never had a problem. Not impressed with the amount of time I’ve spent on forums searching for answers to overcome basic problems. Very frustrating.
07-13-2022 16:30
07-13-2022 16:30
ive noticed that after your done working out, you are sweaty, and if there is too much moisture on the sides of the inspire and/or your fingers, it wont register the side buttons when you squeeze it.
what i have found that works is to pinch the sides of the inspire at the top, and wipe the sides down with your fingers a couple times, then do the side squeeze and they usually work,
