07-11-2022
00:01
22:17
07-11-2022
00:01
22:17
I have had this issue intermittently done I bought my Inspire 2 . I haven’t changed any settings snd wear it in the same wrist but I find that one day will be missing eg Tuesday won’t record but Monday and Wednesday do and I haven’t changed anything .
There is definitely an issue which is not to do with user settings and I wish Fitbit would get to the bottom of it
07-11-2022 05:26
07-11-2022 05:26
@Cinderella99 what is the excuse, for not seeing sleep stages, that the fitbit app is giving you? Is it the same for each night?
Best Answer07-11-2022 08:41
07-11-2022 08:41
It doesn't give any reason - when I sync in the morning, the sleep just doesn't appear.
07-11-2022 08:46
07-11-2022 08:46
Open the fitbit app
Tap the sleep tile.
Tap a sleep in question.
Look under the chart.
Best Answer07-11-2022 09:25
07-11-2022 09:25
Sorry my description was perhaps not specific enough - it doesn’t record a sleep score at all
07-11-2022 14:12
07-11-2022 14:12
But do you get sleep stages? Without sleep stages, there will be no score?
Best Answer07-11-2022 14:26
07-11-2022 14:26
No data at all / no graph no score no stages . I am just left with a day or two missing . There is no pattern to it ; it appears entirely random. My daughter has same issue with charge 4 .
07-11-2022 15:53
07-11-2022 15:53
mine has not tracked my sleep since my complimentary "Premium" subscription expired!
all of my settings are turned on
Best Answer07-11-2022 17:33
07-11-2022 17:33
Same with me. Is there anyone that can help?
Best Answer07-11-2022 17:35
07-11-2022 17:35
Same as cinderella99. It quit giving me my sleep score which is the only reason I'm using the Fitbit.
07-12-2022 02:14
07-12-2022 02:14
No sleep score last night either . It was fully charged , rebooted , correctly on my wrist etc etc . I do wish someone at Fitbit would actually take this seriously instead of making us feel like idiots as if we’re doing something wrong ! There is a bug - they may not know what causes it but there is a bug . I am not sure how it detects you’re asleep and whether that is just on heart rate / no steps but whatever triggers it is either not happening or it is failing at the synch step
07-12-2022 14:08
07-12-2022 14:08
Hi Cinderella99. Support had me restart my fitbit and my sleep score recorded again finally last night. I restarted by holding the side of the fit bit until a smiley face appeared. hope it works for you.
Best Answer07-12-2022 20:07
07-12-2022 20:07
I held the side of mine and no smiley face!
Best Answer07-12-2022 22:56
07-12-2022 22:56
It depends on the model you have I think . On mine I swipe down and get to settings and then select reboot device . However fir the 3rd night in a row no sleep data 🙁
07-18-2022 06:00
07-18-2022 06:00
Well here’s an interesting twist ! No sleep data when I synched this morning but when I clicked on the + next to the sleep score the Fitbit knew when my sleep had started but didn’t seem to know when it had finished as it just put in the current time . When I put in an end time and clicked save the sleep data appeared ! I also did this the other day but only got the simplified breakdown but at least I hit something . So this might be worth trying ..,
