03-20-2023 22:34
03-20-2023 22:34
My Inspire 2 isn't showing my real time heart rate, only my resting HR.
Also it isn't monitoring my sleep at all
03-21-2023
12:39
04:05
03-21-2023
12:39
04:05
Hi @Wendy_Joy. Nice to see you here!
Thanks for the details regarding your Inspire 2.
Can you check if your Inspire 2 is in clip mode?
When you don't want to use your device on your wrist (if you're wearing another watch at the same time for example), you can put your Inspire 2 on clip mode, but this setting will turn off some of the features on the device, including heart rate.
To change your Inspire 2 back to wrist mode, you can press the two buttons on the sides of your device. You will then immediately see "Water Lock" on the screen, but you have to scroll up using your finger so you can see the other options on the menu. If the last option that you see on the menu says "On Clip", that's because your device is currently on Clip Mode, and you can change it back to Wrist Mode by tapping on that option with your finger.
Please let me know if you have any problem to find these settings and if you continue to experience the same inconvenience with your heart rate afterwards.
Best Answer03-21-2023 21:19
03-21-2023 21:19
Best Answer03-22-2023 05:46
03-22-2023 05:46
@Wendy_Joy Swipe up just a little bit more. You should see a check mark and an x in a circle. Tap on the check mark. Then lightly press the buttons to go back to your clock face.
Laurie | Maryland
03-22-2023 18:32
03-22-2023 18:32
03-23-2023
10:01
04:04
03-23-2023
10:01
04:04
@Wendy_Joy I'm happy to know that you were able to change your Inspire 2 back to wrist mode.
@LZeeW thanks for your help. I'm sure this will be useful to other users too.
