Reminders to move aren't working on my Inspire 2
ANSWERED
Not sending reminders to move
1 BEST ANSWER
Accepted Solutions
Hi there, @broshon63. Thanks for stopping by in the Fitbit Community Forums.
This sounds like the Do Not Disturb Mode or the Sleep Mode (Quiet Modes) could be turned on in your quick settings, since both of these options prevent the device from receiving notifications, reminders to move or celebrations. If you haven't done so already, please make sure these feature are disabled in your settings.
In addition, I suggest restarting your Fitbit device by following these steps
In none of the above works, please try setting up the Inspire 2 as a new device in your account if you're still having the same problem. Then repeat the restart procedure and set up notifications to check if they're working properly.
1 REPLY 1
