03-31-2019
11:27
08:56
ManuFitbit
03-31-2019
11:27
08:56
ManuFitbit
Inspire HR repeatedly loses BT connection with iPhone and app gets stuck at “looking” for tracker.
I have done all the resets, restarts, clear data’s, forgets, reinstalls, etc. and same thing every time!!
This is a huge fail!
Come on Fitbit This is ridiculous!!
Moderator edit: clarified subject.
Best Answer05-16-2020 01:27
05-16-2020 01:27
Really fed up now! I have done all the recommended things to get it to sync, it will link eventually (after removing my inspire HR, uninstalling the app, turning off Bluetooth, turning off my iPhone, then turning it back on, turning on Bluetooth, reinstalling the app and then after ages of searching, reconnecting my device, it will sync but as soon as I move or go to do something else it looses connection. Fed up! As someone else said, I’m ready to through it away but it was bought as a gift.
Best Answer05-16-2020 06:51
05-16-2020 06:51
I have iphone8 on iOS 13.4.1!Fitbit is in hell of a mess right how and to be honest is not a lot of use to me unless problems are fixed!
05-16-2020 06:53
05-16-2020 06:53
Best Answer05-18-2020 15:56
05-18-2020 15:56
My fitbit worked fine since I bought it Dec 2019 until May 6 or 7. I called customer support and they assisted me to reconnect but now it’s happening again.
Best Answer05-18-2020 16:32
05-18-2020 16:32
Wonder if there was some new update pushed recently that has affected this. Mine hasn't been great for a while but certainly it has been much worse as of late. Constantly unpairing, re-pairing, doing what I call the Bluetooth hokey pokey (turn it on, turn it off, shake it all about 😀 just to try and have it function as it should). Good luck!
05-20-2020 08:12
05-20-2020 08:12
I have had the same issues for months. Very frustrating to not get my notifications. I miss my Alta HR.
05-20-2020 11:40
05-20-2020 11:40
05-20-2020 14:14
05-20-2020 14:14
Unfortunately, I gave away my old Fitbits when I bought the Inspire....never thought for a second that a newer model would be the source of unending issues.
05-21-2020 09:55
05-21-2020 09:55
Hi, i have done all this Yesterday ... it can’t be right that I have to go through this process several times a week?
05-21-2020 10:19
05-21-2020 10:19
05-27-2020 02:46
05-27-2020 02:46
Same issue. iPhone 6S Plus SS version 13.4.1
Best Answer05-27-2020 04:51
05-27-2020 04:51
05-28-2020 08:28
05-28-2020 08:28
I've been having this issue constantly since the last app update (about 2 weeks ago).
05-28-2020 15:09
05-28-2020 15:09
I know I am a year late to this particular thread, but I had a Fitbit one (actually 2 of them) and was sad when couldn't find anymore
Got an Inspire 2 1/2 years ago and it loses connectivity with Iphone 3 or 4 times a year -- EVERY year.
IPhone 8 or IPhone 10 doesn't matter it's the device, and unlike the One you can't synch this one with online account to solve the issue
Have to fight turning it off - which only works about every 3rd attempt
Then it eventually syncs again - sometimes don;t lose any steps, sometimes lose 2 days as this is how long it takes to synch after 10 0 15 attempts
AGAIN ITS the DEVICE that is a problem
After this one finally dies I will move to an ITouch
05-28-2020 15:34
05-28-2020 15:34
You should strongly consider returning, unless you got a smokin good deal. Problem seems to be ongoing with little appetite from Fitbit to address it. And when it DOES works like it's supposed to for a few days, you get alllll excited, and then BAM! back to not syncing, not connecting, cannot find device etc. Again, not my first Fitbit but definitely first one to have ongoing issues that render it pretty much useless a majority of the time.
Best of luck though! Maybe you got a good one!
15:37
11:04
JuanJoFitbit
05-28-2020
15:37
11:04
JuanJoFitbit
Repeatedly loses Bluetooth connection. Does not sync with iPad for the past week. Today I can only get the correct time. Unable to scroll to get steps etc.
Thanks! Today , though now counting steps, the Fitbit clock time displayed is 3 minutes slower than real time!
Moderator edit: merged reply
05-29-2020 12:54
05-29-2020 12:54
Wow. The issues just keep on coming with this particular device. Maybe the name should be changed from Inspire (which clearly is NOT accurate) to perhaps Retire or Expire. It's not that old of a model but it sure has been riddled with UNinspiring problems.
05-29-2020 17:03
05-29-2020 17:03
05-29-2020 19:24
05-29-2020 19:24
05-30-2020 15:29
05-30-2020 15:29
None of that works. Checked all those, reset everything etc. Inspire will Not appear in the Bluetooth app on my Imac. Will not synch with my Galaxy either. All apps installed, OS updated etc. WTF
