03-31-2019
11:27
08:56
ManuFitbit
03-31-2019
11:27
08:56
ManuFitbit
Inspire HR repeatedly loses BT connection with iPhone and app gets stuck at “looking” for tracker.
I have done all the resets, restarts, clear data’s, forgets, reinstalls, etc. and same thing every time!!
This is a huge fail!
Come on Fitbit This is ridiculous!!
Moderator edit: clarified subject.
Best Answer12-24-2022 04:01
12-24-2022 04:01
You are so right. In the end I gave up and bought an iPhone. Fitbit are useless.
01-25-2023 03:07
01-25-2023 03:07
I’ve done everything you say repeatedly. The device does pair , but LOSES the connection repeatedly and every yime I have to go to settings, forget device even though not paired. wait for pairing request and so forth. Really fed up. I nwver had this problem with my first fitbit , only with the inspire. Is there no solution?
01-25-2023 03:44
01-25-2023 03:44
Best Answer01-25-2023 03:45
01-25-2023 03:45
Best Answer01-25-2023 07:13
01-25-2023 07:13
Best Answer01-27-2023 05:48
01-27-2023 05:48
Best Answer03-27-2023 11:23
03-27-2023 11:23
I have the Versa 2 with Iphone 13 and have to re-pair it at least 5 times a day. I only get notifications on the Versa2 right after pairing and then it is unpaired again so it is unreliable. I even did a restore of my phone and still have the same issue. Been dealing with this for months and have tried all suggestions many times. They need to fix the issue.
Best Answer03-27-2023 11:45
03-27-2023 11:45
Best Answer03-27-2023 12:23
03-27-2023 12:23
