06-18-2019 08:08
06-18-2019 08:08
How exactly do I restart the Inspire HR?
10-26-2020 12:58
10-26-2020 12:58
My inspire hr when I hold the button just starts the stop watch. I can not get it to restart. Any ideas?
10-28-2020 09:33
10-28-2020 09:33
I find that the HR needs to sync with your phone. After charging I hold the phone and HR two side by side and then press the side button. After that I read the display and see if the syncing starts. When it does sometimes it needs to update as well. I do this on my phone. You will see it syncing there.
That's all I can say.
12-09-2020 15:34
12-09-2020 15:34
Thank you that worked
12-28-2020 08:45
12-28-2020 08:45
It means nothing the important part is the smiley face
01-10-2021 22:29
01-10-2021 22:29
Hello, if you have a charge 3 here are some instructions,
put the Fitbit watch on charge (make sure you have the pins connected)
hold the power button for 3 seconds and then if you see the smile face, then your charge 3 is restarted.
if it fails to respond, leave the watch for 24 hours and try again.
if it still does not respond, call the customer centre on its contact us page.
these instructions are what I did with my charge 3 and not available on any other device.
Thanks
01-21-2021 10:40
01-21-2021 10:40
I am having exactly same issue setting up one has anything worked?
01-21-2021 11:06
01-21-2021 11:06
03-04-2021 17:01
03-04-2021 17:01
I've tried this a dozen times and it won't reset. Is there anything else I can do?
03-05-2021 06:53
03-05-2021 06:53
I have to hold the button for a good long while not the few seconds they say and all of a sudden a smiley face will show up. Make sure the connection to the charger is food or it will not work. My connection slipped a couple of times and it did not reset.
03-05-2021 08:29
03-05-2021 08:29
03-08-2021 12:39
03-08-2021 12:39
03-09-2021
04:57
04:18
JuanJoFitbit
03-09-2021
04:57
04:18
JuanJoFitbit
Just reboot your Inspire HR, and if that does not work then contact fitbit
support. That is what I did and they helped me out through each step.
Contact fitbit support, they will help. That is what I did.
Moderator edit: merged reply
03-09-2021 12:40
03-09-2021 12:40
04-05-2021 20:45
04-05-2021 20:45
Try unpairing and then re-pairing the bluetooth, that has worked for me when this happens.
04-06-2021 10:08
04-06-2021 10:08
04-25-2021 06:51
04-25-2021 06:51
Hi I have tried this a couple times and I still get nothing 😔, no smiley face I got a vibration once. Is there anything else I can do or do you think the face is done?
04-25-2021 18:23
04-25-2021 18:23
08-17-2021 04:17
08-17-2021 04:17
Having the same problem, get the smilie face but no vibration and won't do anything but show the time only when I press the button.
08-17-2021 20:45
08-17-2021 20:45
08-18-2021 00:24
08-18-2021 00:24
I noticed that the app was updated yesterday. Now I can’t get my Inspire HR to sync with it. Might try rebooting it. Hope that works. So annoying!
