07-24-2019 09:35
07-24-2019 09:35
The face of my Inspire HR is very scratched. I have tried the toothpaste technique with no success. I have purchased a screen protector for my device but I’d like to clean it up first. Any suggestions or products that anyone can recommend?
07-26-2019 10:15 - edited 07-26-2019 10:23
Hi @SunsetRunner welcome to the Community Forums. Hope you are doing great and enjoying some healthy activities.
Thanks for letting me know how you're cleaning your Inspire HR screen. Your Fitbit screen is made of Grayscale OLED, we recommend to clean it in the same way you clean yourTV screen of eyeglasses. Some users have reported the following tips:
To clean your bands you can check the Wear & Care instructions.
Let me know if you need more information.
07-27-2019 03:58
07-27-2019 03:58
08-12-2019 07:55
08-12-2019 07:55
It would be very helpful to know how to get the scratches off the screen. Is there a way to get the scratches off or replace the screen?
08-12-2019 07:56
08-12-2019 07:56
Where did you get a screen protector for it? Do they make them that small?
08-12-2019 08:31
08-12-2019 08:31
I got a screen protector on Amazon. 6 pack
from HK. A little tricky to install but covered up the old scratches and protects going forward.
08-13-2019 06:46
08-13-2019 06:46
I scratched the face while trimming shrubbery. I remembered hearing that a little toothpaste would remove scratches from cds. It worked on my Fitbit! Loooks good as new. Now if it would only sync regularly . . .
08-13-2019 10:35
08-13-2019 10:35
08-13-2019
17:30
10:57
YojanaFitbit
08-13-2019
17:30
10:57
YojanaFitbit
Would you happen to have a link?
Moderator edit: Word choice.
01-02-2020 15:05
01-02-2020 15:05
My face got very badly within a week of use, do bouldering and didn't even feel it touching against any of the rocks but was in very bad condition, support team said there's nothing they can do warranty wise which is a shame only after having it a week. Tried tooth paste, autosol, using a buffer machine etc but the scratches are super stubborn, if anyone else has any luck let me know spend hours trying to remove these scratches.
01-02-2020 15:06
01-02-2020 15:06
my fitbit face got scratched very badly*
07-08-2020 06:23
07-08-2020 06:23
Same thing happened to me. I have scratches on the face after about two weeks and didn't even feel when it would have happened. Toothpaste didn't work either. 👎🏼 I keep buying FitBits and should not. They don't last.
07-08-2020 10:04
07-08-2020 10:04
07-08-2020 12:34
07-08-2020 12:34
07-08-2020 12:35
07-08-2020 12:35
I purchased the exact same two items. I gave up on the first item. Wasn't really what I wanted. The screen protectors are fine. I change them every month or so and you can't see the scratches. A good solution.
