Screen Wake isn't working on my Inspire HR
ANSWERED
Inspire HR screen doesn't appear when I rotate my wrist how can I correct it?
1 BEST ANSWER
Accepted Solutions
Hi there, @Shooter1. Welcome to the Community Forums. Thanks for the details provided about the inconvenience with Screen Wake feature.
As @JohnnyRow has suggested, please go to your quick settings and check that screen wake hasn't accidentally been turned off. To do so, press and hold the button, tap a setting to turn it on or off. When you turn off the setting, the icon appears dim with a line through it.
If this settings is set correctly, please try restarting your Inspire HR by following these steps: How do I restart my Fitbit device?
Hope that helps.
2 REPLIES 2
Probably have Screen Wake turned off; if not might be in Sleep Mode.
Can see both in Quick Settings by pressing side button a few seconds.
Hope that helps.
