11-22-2021
12:17
23:01
11-22-2021
12:17
23:01
My watch is no longer showing an active screen when I bring my watch up from being in a down position. It’s downright irritating!
why had this suddenly stopped working?
11-23-2021 13:05 - edited 11-23-2021 13:06
Hi there, @julesjmj. Nice to see you around the Community Forums. Thanks for trying to troubleshoot the issue with your Inspire 2 before reaching out. I understand where your concern is coming from.
@OfficialThomas Thanks for jumping in!
You can use the screen wake option here:
Hope it helps.
11-22-2021 15:19
11-22-2021 15:19
Let's get this fixed!
Before we go into deeper troubleshooting make sure that "screen wake" is turned on and "sleep" mode is off. You can adjust these settings by holding both sides of the inspire 2 and then selecting the desired setting.
Let me know the results.
11-22-2021 22:33
11-22-2021 22:33
I’ve double checked and made sure that sleep mode is off, but I don’t know where to find the screen wake setting.
Hope it helps.
11-23-2021 16:19
11-23-2021 16:19
Ah, you are fabulous. Found it, fixed it and it works now. I had been wondering if there was another way the dnd setting could change without me knowing it and now I realize it is through this same mechanism.
thank you!
11-24-2021 10:37
11-24-2021 10:37
@julesjmj I'm glad to see that you're able to find what you were looking for. 😊
Have you checked our Health & Wellness forums? If you're into Fitbit and fitness you may enjoy other users' comments. Check this board Looking for Fitbit Friends? Find some here! And have some fun interacting with other Fitbitters!
See you around.
12-28-2021 21:10
12-28-2021 21:10
how could i do?
07-23-2022 05:03
07-23-2022 05:03
Hi. I’ve tried this but when I tap on Smart Wake nothing happens, so I can’t turn it on. Same with DND setting. But others (water lock, on wrist etc) seem to be working fine & turn on and off as normal. I’ve restarted the device but still no joy. Can anyone help? Thanks
07-23-2022 05:05
07-23-2022 05:05
That’s sorted it! I had sleep mode on. Thanks!
