11-09-2022 17:25
11-09-2022 17:25
My daughter's original Inspire has had the screen gradually becoming more dim. It started with just the bottom of the screen being more dim, and now has spread to the whole screen to the point that you can barely read it inside and it is just a black screen when outside. We have checked and the Dim setting is turned off. We have rebooted it several times and nothing seems to help. Any suggestions?
11-09-2022
18:11
03:40
11-09-2022
18:11
03:40
@ang79 , A warm welcome to the Community! Thank you for your efforts with the restart.
Our team has been informed and you'll get further assistance via email .
You'll receive a message soon.
Hope this gets solved soon.
01-20-2023 14:38
01-20-2023 14:38
I have been noticing the same issue lately with mine. It is definitely becoming more difficult to read indoors. It’s never been visible in direct sunlight.
02-01-2023 20:31
02-01-2023 20:31
What's the status of this issue? I suspect firmware updates are the problem as the battery charge progress bar is considerably brighter but the functional screens are dim after checking that the sleep and do not disturb settings are correctly set. No change after reboot or factory reset which loads the current firmware.
02-01-2023 20:38
02-01-2023 20:38
