07-11-2019 10:37
07-11-2019 10:37
Screen too dark to see snything
Best Answer07-12-2019 11:51
07-12-2019 11:51
Nice to see that you're digging into the Forums @amlavin, let me give you a warm welcome to our Community. ![]()
Thanks for reporting the issues with your Inspire screen. Are you able to see the display clearly indoors? In case that you're having issues reading your Fitbit Inspire screen, please try to restart it with the following steps:
Your tracker should now work normally. If your tracker still doesn't work after a restart please let me know.
I'll be around.
09-15-2019 16:00
09-15-2019 16:00
I'm having the same problem. I can read the display fine while indoors, but it's extremely difficult to see when outside. There is not enough contrast. I didn't have this problem with the Charge 2.
09-15-2019 17:41
09-15-2019 17:41
thank you mine is working now
Best Answer01-03-2020 08:58
01-03-2020 08:58
Hi there,
I'm having the same issue but when restarted, there is no change. Dimmed or not, it makes no difference.
