10-28-2020 05:03
10-28-2020 05:03
When I try to set my bedtime and wake up time on my Fitbit Inspire I don't have the option to save it. The only two options are Remove and Cancel. Very frustrating if Fitbit can't be used like it claims.
10-28-2020 09:46
10-28-2020 09:46
Android phone app, not Inspire but think phone app is the same:
I have options, Remove, Cancel, OK. Do you not have the OK option? I change time on the clock and click OK and it seems to be saved.
01-10-2021 05:28
01-10-2021 05:28
I have same issue and tried troubleshooting this too. I checked to make sure I have latest software, which I do, still have not solved this. Any resolution?
08-17-2021 00:48
08-17-2021 00:48
I have the same problem. Here is a screenshot.
Thanks RhondaR67 for opening this thread. I thought there was something really obvious in the app's navigation that I wasn't seeing. Whatever it is, it's good to know it's not just me!
08-17-2021 00:49
08-17-2021 00:49
There is no "ÖK" option.
08-17-2021 04:06
08-17-2021 04:06
I've managed to solve the problem. It's a font size issue.
You gotta reduce the default font size on your phone's display settings. Once you do that the 'ok' button will show correctly.
I followed instructions as per this other post:
https://community.fitbit.com/t5/Other-Charge-Trackers/Can-t-set-bedtime-on-Charge-3/m-p/4662972/high...
