02-23-2021
19:35
03:32
AlvaroFitbit
02-23-2021
19:35
03:32
AlvaroFitbit
Does anyone have tips for how to set up / use the Inspire when you can only wear it some days or part of the day ? For example, is there a way to set goals that are different depending on the day of the week? (I can usually only wear at night / overnight and on weekends - I can't wear it at work, including on the clip or ankle, due to safety rules).
02-24-2021 04:54
02-24-2021 04:54
@JohnR7 It's great to see you in the Community!
Let me help you with this. As @Odyssey13 said, if you can wear your tracker inside your pant's pockets it will track your steps without being in the way but if you really can't wear it at work ( for example I know some places ban bluetooth devices in general) then you could manually log an activity to have a record of your estimated steps you walk while working.
Hope this helps.
02-23-2021 20:41
02-23-2021 20:41
Hi @JohnR7 there is no way to use the Fitbit part time. Are you able to use it if you put it into a pocket?
02-24-2021 04:54
02-24-2021 04:54
Hope this helps.
