Silent alarm on/off toggle?
Am I supposed to be able to turn off a silent alarm from the tracker itself?  For example, I have a weekday one for 5am.  But if I have the day off, it looks like I should be able to tap the alarm and turn it off.  (The alarm greys out with a strikethru on it).  When I do that, the alarm still goes off.  Am I doing that wrong?  Or is that not what it is supposed to do?  This would be much easier than changing it on my phone and syncing.
1 REPLY 1
Hi @SoCalSD Yes you should be able to turn an alarm off on your Inspire itsself, as you say, by tapping the alarm. If it still goes off when you do this, Id suggest you remove the alarm in your phone app and sync, then restart the Inspire several times and then reset the alarm in the app and sync it and see ifnit behaves properly then. Very annoying to be woken at 5am when you have a day off!
Restart your tracker
Community Council Member
Helen | Western Australia
