11-25-2022
03:36
20:58
11-25-2022
03:36
20:58
Hi there,
I’ve checked the others threads but my Inspire 2 does sync, or at least it says it does, and I double check my alarms before I go to sleep and then the wrong alarm goes off and/or the right alarm doesn’t go off. It shows it has synced but then, at some point, it changes. This is really a problem as I rely on this feature heavily for both wake up and day time use. I’ve tried a hard reset and uninstalling the app to no avail. Please fix this bug. Also, I agree that the multiple alarms are annoying and the silent alarm screen has never been seamless to use.
Moderator edit: format
11-26-2022
11:56
06:37
11-26-2022
11:56
06:37
Hi, welcome to the Fitbit Community forums, @MWswimrunsleep.
Thank you for sharing that you've been experiencing this problem with your Inspire 2.
Before considering other options, please try removing and re adding the alarm and then Restart your device as well, as this has been useful for other users experiencing something similar.
If you're still having this issue, you can also try setting up your Inspire 2 as a new device in your account.
I'll be around.
