Silver steel strap Inspire 2
Hi all, thinking if lf buying a silver steel strap for my inspire 2, I know you need a small screw driver to adjust the steel strap for your wrist size but I assume you can take the fit bit on and off each day without needing the screwdriver every time?
thanks!
2 REPLIES 2
@AoifWW , absolutely!  You only need the screw driver to lift the little catch that locks the wrist adjustment to the correct size.  Once you have got it set to the correct size you just press it down again to lock it in place and then you can take in on and off without any help or instruments.  Works easily.  I have one and it looks very nice!
Thank you very much for that!
