09-13-2019 14:14
09-13-2019 14:14
Sleep score isn’t showing up. It’s tracking the length of time I’m sleeping. It’s tracked my score before but it doesn’t work consistently. How do I fix this?
08-29-2020 19:11
08-29-2020 19:11
Ok will do. I’ll see what happens tonight. 👍
08-31-2020 15:29
08-31-2020 15:29
Hope it works for you. Mine is doing everything it is supposed to do now.
09-04-2020 10:31
09-04-2020 10:31
My heart rate is ON and I always let it detect my sleep but my Sleep Score and Hours in Sleep Stages stopped working August 22nd when I did the firmware upgrade. I hate when an upgrade is actually a step going backwards.
It's not what I use the Inspire HR for mostly but it was nice to know.
09-05-2020 15:19
09-05-2020 15:19
This worked perfectly for my Charge 4.
09-06-2020 03:40
09-06-2020 03:40
Glad it worked for you!
09-09-2020 08:05
09-09-2020 08:05
This worked perfect and exactly like you explained. My sleep scores showed up for the days I deleted and re-entered!
thank you!!
09-09-2020 13:04
09-09-2020 13:04
Ive had a problem for over 3 weeks. The score was shown but NOT the restoration sleep graph. Ive done a phone update along with a Fit Bit one. No result till yesterday and the graph has been back for 2 days now. I even thought of cancelling my premium membership as I was so fed up with this problem. I hope its fixed long term now!
09-09-2020 16:37
09-09-2020 16:37
09-09-2020 16:41
09-09-2020 16:41
Glad it worked for you Susieanne.
09-10-2020 02:59
09-10-2020 02:59
I’ve had my Fitbit for over a year. I never had a problem getting a sleep score until the app was updated recently. There have been four days in the last week where I have gotten simplified results. My watch is charged, and I wear it as recommended. I think a fix needs to come from Fitbit.
09-10-2020 10:03
09-10-2020 10:03
Totally agree. My Sleep Score stopped working after the latest firmware upgrade.
Nothing has worked for me so I guess I have to wait until Fitbit fixes it.
11-06-2020 08:09
11-06-2020 08:09
I've used this watch for several months so I think I'm starting to see what's up with this situation. When the fitbit app on my phone says that no sleep score could be calculated it has a "learn more" on that same screen that you can click on those words and it takes you to a website that tells you possible reasons. The main thing I have found that solves this MOST of the time is wearing the watch up my arm so that when I bend my wrist, the watch does not move and lose signal. And wearing it tight enough. The web page basically says that if the watch loses contact with heart rate intermittently, and for too many gaps in heart rate signal, the app won't show a score. Because of that, you also generally won't get the 2nd graph in that app that breaks down REM sleep, light sleep, and awake. That is a graph in addition to the basic graph that I find always shows up but is not as in depth. But I've often gotten that 2nd graph but still no sleep score. In my opinion, if I don't even get that graph that also means it lost heart rate signal too much. I also I think to get the score there has to be a long enough period of sleep data in the first place. So you need to get enough sleep on that graph in the first place, in order to register the score. Not only is position on arm important you also have to wear the watch tight. So that website says wear it 2 to 3 finger widths above the wrist bone and that the watchband should feel "secure but not tight". I would say it needs to be tight but not painful lololol. It also states 2 OTHER reasons, if you slept for less than 3 hours or if battery is critically low. But I've had well over 3 hours of data with battery fully charged and still no score. So it must be the heartbeat signal loss and insufficient length of data. But mainly loss of heart rate signal during night. To resolve that, for me it's always the position of the watch and how tight it is. However, this thing is dang sensitive about getting moved. And there are muscles on the top of your arm that run the wrist. So if you put it up too far on arm it'll be right on those muscles and won't work either. Maybe try wearing watch on underside of arm and see what happens. I'm pretty sure that the intermittent loss of heart rate is generally the key. I have tried finding the actual URL for the website but the app doesn't state it. It's just when you click on the "learn more" in the "Why I didn't get a sleep score" in the phone app. If you can find that website, you'll get this same information I'm explaining here. The other cool thing is that they've added the capability to get your average oxygen level while you sleep. Not sure how accurate that is but I think it's as accurate as ones that go on finger. I'm considering testing both on same nights and see what data looks like over several days. Sorry for long explanation but if you buy this expensive watch it's very frustrating if the expense seems wasted.
11-19-2020 07:44
11-19-2020 07:44
What seemed to work for me, because I had the same issues all week. Took my sleep score the first night and nothing the last few. But last night I didn’t bother hitting the sleep button. I just went to bed without dealing with it and it actually tracked my stuff properly. I’ll try again tonight and see if that seems to be the fix.
02-07-2021 02:36
02-07-2021 02:36
Thanks ovyy222
This helped me get sleep data. Strange how this resolved.
