08-22-2022
04:51
20:58
08-22-2022
04:51
20:58
Literally only bought this for the sleep score and it’s not showing up. Why is this?
08-23-2022 05:53
08-23-2022 05:53
Quick fix all on the bracelet not the app. Go into setting and check the following 3 things.
1 sleep should be greyed out
2 DND should be greyed out
3 Band should be set to wrist not clip
I did this yesterday and I have sleep details this morning. Need to wait 4 days for the other info but I am hopeful that this too will work.
Best Answer08-22-2022 05:18
08-22-2022 05:18
I have the same problem. How can we get advice or customer support. So far it is just a rip-off
08-22-2022 09:20
08-22-2022 09:20
Me too upgraded to premium and the only thing that works now is steps ? Let me know if you get a solution
08-22-2022 10:50
08-22-2022 10:50
Why is there no support for us???
Sleep not recording for a week now ???????
08-23-2022 05:53
08-23-2022 05:53
Best Answer10-21-2022 04:47
10-21-2022 04:47
Where should I be looking for this area you say should not be grayed out? On the wristband it just says “no score“ and on the app it just tells me the hours I slept but doesn’t give me a score.
Best Answer10-21-2022 05:27
10-21-2022 05:27
I have the same problem. I spent hours going back and forth with tech support and still can't get it to record properly. Apparently I only sleep 1 to 2 hours a night. I don't know what I am doing for the other 6 or so that I am in bed
