03-26-2019 03:39 - edited 04-06-2019 06:29
The sleep section is darkened, while the water section shows zero even though the app shows 1000. Tried syncing the device and restarting it but doesn’t work
Moderator edit: Updated subject for clarity.
Edit: 06/04/2019: Data still not showing. Factory reset, restart still doesn't help. Forget device doesn't help.
09-24-2019 02:53
09-24-2019 02:53
09-24-2019 02:55
09-24-2019 02:55
09-24-2019 02:56
09-24-2019 02:56
That sucks - mine is fine after I did what I advised others to do...
09-24-2019 02:57
09-24-2019 02:57
09-24-2019 02:57
09-24-2019 02:57
09-24-2019 03:00 - last edited on 06-24-2021 06:12 by JuanJoFitbit
That is too bad - this is my second - had the Alta HR and had to learn how to use it as the problems I had were user error IMO. Upgrade to the Inspire this last Spring as I am a swimmer and have no problems at all with it but understand how to use it after the Alta...good thing too since I purchased them both off of ebay as the price there was so much better.... lold
One would think, but I have read too many posts over the last few years proving that many are technically illiterate. I am not and had iPad/IPd computer issues with the fitbit app but once l too the time to understand the issues the problems disappeared.
Moderator edit: merged reply
09-25-2019 13:34 - last edited on 06-24-2021 06:14 by JuanJoFitbit
Thank you for advice. Did all steps, and after water is working, but sleep icon is still not active. Someday app working right: sleep stages is tracking automatically, but somedays not working completely. Please help.
Hi, please advise there's SENSETIVE option.
10-02-2019 06:31
10-02-2019 06:31
I have the same issue - the fitbit app shows my sleep cycles but on the tracker itself the moon icon is greyed out and does not show any data.
Have tried unpairing and paring again, tried to restart the tracker, tried to update it, all didn't work.
How do I fix it?
10-02-2019 14:13
10-02-2019 14:13
12-07-2019 03:10
12-07-2019 03:10
I got my new device today for it sleep icon is grayed out any solution.I see this thread waiting for response from long time.
12-07-2019 10:30
12-07-2019 10:30
12-07-2019 18:27
12-07-2019 18:27
01-01-2020 08:14
01-01-2020 08:14
I’m having the same issue. I’ve tried the trouble shooting steps, and it will work for the remainder of the day, but the next day it shows up blank again and doesn’t update.
03-10-2020 01:52
03-10-2020 01:52
Yep same here
03-21-2020 16:33 - edited 03-21-2020 18:16
I turned my notifications off then back on and did a sync with my phone and the water and sleep show up on my tracker now! Not sure how long this will last... I'll add an update in a few days.
Update: 2 hours later I added some water to phone app. Synced. No change on tracker. Tried the notifications off/on trick, no changes.
It's not the end of the world, but like y'all said, we're paying for this to work as advertised!
03-22-2020 16:18
03-22-2020 16:18
Nothing works... you apparently have to buy a premium subscription to get the sleep data back. This appears top be a classic bait and switch tactic that warrants us all sending our fitbit devices to thew trash and get one from Garmin who will not pull this crap.
03-22-2020 19:08
03-22-2020 19:08
Well I’m sad you’re having that problem I’m on my second Fitbit I’ve had the inspire HR for a little over a year I don’t have that problem and I work nights the only problem with the sleep I have is Due to my hours since I get up at midnight it’s a day behind on my days but it’s current on the calendar days water shows providing a log it in which I don’t bother doing because I’m pretty good at keeping track of my own drinking but everything else works like a charm I use an Apple phone
05-12-2020 11:41
05-12-2020 11:41
I've had this FitBit for ONE WEEK and have the same issue with the sleep data not showing up. It was working fine until this morning. The app won't show my sleep from last night and the sleep icon is grayed out on my tracker. Seriously, one friggin week. What a piece of crap.
05-12-2020 17:19
05-12-2020 17:19
My sleep icon is not working now, tried all the suggestions and nothing is helping. Very frustrating
05-13-2020 22:11
05-13-2020 22:11
I have the same issue and I did follow the steps you had asked to do. But I still have this problem.
