08-10-2020 05:09
08-10-2020 05:09
During a weekend away, my wife chose to take a short 'nap' during one afternoon. Unfortunately, this has now put the 'Hours Slept' history a day out.
(If attached properly) the image shows her sleep record up to this morning (Monday 10th Aug) and the 'Last Night' correctly shows as Sunday Night (right hand panel). The left hand panel, shows last night as being Monday Night, so a day early. This has been the case since the 'nap' during our weekend away.
How do I reset this left hand 'weekly total' panel, as I am unable to find a way of doing this.....Sleep record a day out...
08-10-2020 05:39
08-10-2020 05:39
You can delete the nap sleep log. Select the nap sleep log, tap the three buttons in the upper right of your screen and select delete. You may have to sync your Fitbit again in order for the chart to update.
08-12-2020 04:13
08-12-2020 04:13
Brilliant - Thank you.
Will get onto that and resync later today.
Regards, RickS
08-19-2020 02:33
08-19-2020 02:33
Thanks again for the sugestion.
It has removed the odd little 1.5 hr 'nap', but the graphs on the left hand side of the panel are still a day out. No matter, we can llive with it as the data in the right hand panel is correct.
Thanks again.
