Sleep score stopped on Inspire HR
Good morning. I had a Flex 2 and upgraded to the Inspire HR in January. The sleep score has worked since I updated the device but it quit working a week ago. The only things I changed were the band and I had the protective case around the device but took it off when I changed the band. I have changed the band again but haven't put the protective case back around the device and it's still not recording my sleep score. Should the protective case be put back on it or should something be reset? Maybe the placement on my wrist isn't correct but it's the same as it has been since I upgraded to the Inspire HR. Any feedback would be greatly appreciated.
4 REPLIES 4
Mine is the same way.  I have had mine since August and worked fine.  I signed up for premium and it never worked correctly.  I cancelled and have had 2 chats with fitbit.  Now it is worse.  It tracks nothing. They told me to change the sleep setting to sensitive which is way too much info but I did and now I only get restless reading.  And the sleep time is even wrong as of today. I am going to chat one more time.  The last guy told me they are having issues and hope to fix it.  Watch for updates he said which I have never had in all my years of fitbits.
Just read the time issue.  That was easily fixed but not quite sure why that would happen.  I forgot to mention that mine always says heart rate not detected.  It has for weeks.  During the chat he said that is a common problem which I have noticed on here.  I thought I had a heart issue!!!!!!  LOL.    That is why I bought the inspire in the first place.  It works fine during the day and is always spot on.
We purchased an Inspire when my wife's Fitbit One died after about 6 years. We are only interested in step and sleep tracking so the Inspire seemed like the best bet. It tracked my wife's sleep for the first 2 nights and then stopped. We called Support 3 times about this issue. The first time they made some minor settings changes and rebooted the Inspire. The second time, they set the settings back to where they were. The third time, they didn't know what to do. I suggested that since the product was defective, they should send me a new one. The agent told me that the problem wasn't in the product, it was in their system and the technical team was working on it. I asked to speak to a supervisor and she told me that the Inspire didn't monitor sleep. I informed her of two things: first, the product description clearly states that it does sleep tracking and, second, it had tracked my wife's sleep for 2 nights. She reluctantly agreed to send us a prepaid return label for a refund.
I have some issues with the way that Firbit says that they automatically track sleep. According to their literature, you have to go to bed and be motionless for an hour for the Inspire to determine that you are asleep. This is preposterous, of course. Who remains completely motionless for an hour? For example, suppose my wife gets in bed and drifts off to sleep after 10 minutes. 55 minutes later, she turns over. The Inspire, according to Fitbit, would not assume that she was or had been asleep. The hour of being motionless would be reset. This sequence of 55 minutes motionless then a movement could go on all night, in which case, the Inspire would never go into sleep tracking mode. It seems to me that the basic algorithm is wrong. I would much prefer manually activating the sleep tracker as the Fitbit One did. We are very unhappy with Fitbit, not just because their product doesn't work as advertised, but also because their customer service, which was quite good 6 years ago, is not very good today.
I had already restarted the device yesterday to see if that would work but it didn't.  I chatted with an agent online about the issue.  She checked my device and noticed that in the settings, the heart rate was turned off.  She said that's a reason I wasn't seeing the sleep stages and score.  So for the next 24 hours, I'll wear it as normal and check it again to see if that worked.  I have no idea how I turned that off in my settings but I'm guessing I done it somehow when I changed my band or when I put the protective piece on it.  Hopefully it'll work now.  I'll know tomorrow.  🙂
