02-25-2020 07:07
02-25-2020 07:07
I just started using the Inspire HR. The sleep tracking looks good, but it is ending too early. Is there anyway to adjust the end time? I seem to remember on the Fitbit One I could manually adjust the start and end times after the automatic sleep was recorded.
15:24
11:03
02-26-2020
15:24
11:03
@Nlynne Welcome to the Community. I'll be happy to clarify your inquiry about sleep tracking.
It's possible to edit your start and end time of your sleep graph. Please follow this procedure to edit your sleep graph:
- Go to your Fitbit app
- Search the sleep graph you would like to edit
- Tap on the sleep > tap the pencil icon
- Edit it and tap on save
Additionally, please make sure that you're getting a consistent heart-rate reading or wore it too loosely. For best results, wear your tracker higher on your wrist (about 2-3 finger widths above your wrist bone). the band should feel secure but not too tight.
Keep me posted.
