12-21-2023
13:32
10:42
CrisVillaFitbit
12-21-2023
13:32
10:42
CrisVillaFitbit
It shows wrong STREAK counter. I'm doing more than 10K STEPS since March 15, 2023 but it shows STREAK COUNTER as 37. Calculation is wrong. I talked to REP and she mentioned that it's removed in INSPIRE 2.
If it's removed then why it's showing wrong counter in the APP.
I suggest : Either fix it or Remove it..
Moderator edit: edited title to clarity
12-26-2023 10:44
12-26-2023 10:44
Hi, @AviGupta Welcome to the community!
Thanks for letting me know about this situation with the streak counter for steps on your Inspire 2.
I was able to confirm you contacted support via chat and they were able to provide you with a solution, if you have any other questions or concerns, my best recommendation would be to contact them.
