02-06-2023 11:13
02-06-2023 11:13
Overnight my Inspire 2 dashboard switched from steps to calories in the big graphic displayed. I didn’t change anything in my setting - it still has steps listed as my primary goal, but it isn’t displaying like that.
02-06-2023 11:25
02-06-2023 11:25
Hi, @snchrist! Many people are having problems with the app being down right now (or half functional). Fitbit is aware of the issue (see the pink banner). Hopefully it will be fixed soon. Many people have already said they've seen it be fixed.
MakMak | Community Council
02-06-2023 14:00
02-06-2023 14:00
I had the same problem today! Finally got a CHAT going. Here's how I fixed it (with guidance):
On that screen tap the edit button. You should get the same calories tile with an x on the circle around it, plus the other 3 tiles below it in gray with a + on the circles. Tap the + for the one you want on top and the x on the one you don't want up there. If you want a secondary choice to show, tap the + on that one. The + signs on the ones you chose will become x-s.
02-06-2023 17:57
02-06-2023 17:57
Same here. Suddenly steps are calories burned. Not fixed yet as far as I can tell.
Best Answer02-06-2023 18:00
02-06-2023 18:00
Thanks for the guidance. Worked!
