Struggling to setup Inspire on my android phone
Just purchased inspire. Struggling with setup on my android.  Have the fitbit logo in screen with website link scrolling.
1 REPLY 1
@Mrso99uk It's good that the community is growing!
Let me help you with this. I suggest you clear the link between your phone and your tracker by doing the following:
  1. Go to your phone's bluetooth settings and remove all devices listed there.
  2. Restart your phone and restart your device
  3. Check that no battery saving app/feature on your phone is affecting your Fitbit app.
  4. Also, on an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
  5. You can find troubleshooting instructions here.
Hope this helps.
Alvaro | Community Moderator
