02-24-2020 16:33
02-24-2020 16:33
I've been having problems reconnecting my dropped bluetooth on my Inspire many times a day which I see many other are experiencing also with no advice that seems to consistently work. This has been happening to me since I got it last fall. Today I hopefully found something that has successfully connected immediately over 8 times for me today. When I place my phone and Fitbit device face to face while the app is open and then try the resync it seems to connect within a few seconds. Hopefully this will help. Let me know if it works for you. Good luck!
Best Answer02-24-2020 18:01
02-24-2020 18:01
Well done on the troubleshooting! I hope it continues to work for you.
Helen | Western Australia
Best Answer02-28-2020 05:15
02-28-2020 05:15
As stupid as it sounds, so far so good for the last few days! As long as I check that the bluetooth connection is connected to the device and then going back to the app, the app seems to connect to my android phone in a few seconds when I place it face to face.
