08-13-2020 21:06
08-13-2020 21:06
I've decided to take a 3 month hiatus from being attached to a tracker. I have a Fitbit Inspire. Is there a way to turn it off? Or should I let the battery run out then recharge after 3 m? Will it work then and continue to sync with the current app?
08-14-2020 05:49
08-14-2020 05:49
Hi @Tatdell
Once you charge it after the 3 month break, it should be fully functional again. You should store it in a cool, moisture-free place. If your break goes longer, just make sure you charge it to 100% at least once every 6 months.
08-14-2020 08:57
08-14-2020 08:57
Thank you! That sure helps. Will let it drain completely then.
