05-31-2019 17:09
05-31-2019 17:09
Hi
I am using an Alta HR and would like to buy an Inspire HR as well.
Is it possible to sync both devices to the same account on my iPhone?
Thanks in advance
Best Answer05-31-2019 22:33
05-31-2019 22:33
Hi @iFiNi Yes it should be fine to do that. However I have found I have difficulties with my trackers when I do that and have reluctantly moved them on to separate accounts. The problems I have are syncing problems (yes they do sync, but it is slower and more difficult) and notifications (they only seem to work with one tracker). My phone is on the Supported Devices List so should work. As to whether yours will work together - I think trying is the only way to find out fpr sure.
Helen | Western Australia
Best Answer05-31-2019 22:59
05-31-2019 22:59
Thanks so much NellyG
Just bought the Inspire HR. Hope it works fine
Cheers!
