09-07-2021
12:25
10:07
SilviaFitbit
09-07-2021
12:25
10:07
SilviaFitbit
My dashboard underreports the number of steps that my Fitbit shows every day. There doesn't seem to be any pattern that I can detect. It typically reports daily totals between 25% to 50% of what my Fitbit device shows. Is there some manual procedure that I need to do at the end of each day to get it record my steps?
09-08-2021 10:10
09-08-2021 10:10
@DaveC42 Welcome to the Fitbit Community. I moved your post to this board, in an effort to keep the forums organized.
Thanks for the details mentioned.
May I know if you have MobileTrack added to your account? MobileTrack is a feature that records basic stats such as steps using your phone's sensors if you don't have a Fitbit device available.
If this is the case, let's try the following steps:
To ensure your Dashboard reflects the same data tracked by your Inspire, make sure that it syncs to your account prior checking it.
Hope this helps.
