07-18-2020 10:45
07-18-2020 10:45
How do I set my fitbit to track my walk? We walk between 3 and 4 .miles every day my fitbit says I have 10467 steps for 2.64 miles while my Samsung health app (which has GPS tracking) says I hav 9840 steps for 4.42 miles. I know I take about 2200 steps per mile. Is there a way to adjust the steps per mile in the fitbit app?
Best Answer07-18-2020 11:11
07-18-2020 11:11
After you track a run with GPS, your stride length updates automatically. For best results, run at a comfortable pace for 10 minutes or more. For more information, see How do I use GPS on my Fitbit device?
You can also measure your stride length manually and add it to your Fitbit account.
How do I measure my stride length?, and tap your profile picture.
> Settings.
Best Answer07-18-2020 12:12
07-18-2020 12:12
Best Answer07-22-2020 07:51
07-22-2020 07:51
Today we walked 3.98 miles according to my Samsung health app - but my fitbit app says 2.39 miles. I have set my stride length. I know that I have 2438 steps in a mile but the fitbit is calculating it at 3955 steps in a mile. How do I get the fitbit to recalculate to the right number of steps per mile? If I use the GPS on my tracker will that calculate the steps correctly?
Best Answer07-22-2020 15:08
07-22-2020 15:08
@Stella46 wrote:
If I use the GPS with my fitbit will it update the steps to the steps I take in a mile and set it at that number? Sent from my Verizon, Samsung Galaxy smartphone
The easiest way to know for sure is to try it. Note your stride length; go for a GPS-measure walk; then check stride length again to see if it has changed.
I'm not sure if it reset stride length for run and walk or just for run.
Best Answer07-24-2020 17:34
07-24-2020 17:34
