05-03-2021
03:56
04:23
AlvaroFitbit
05-03-2021
03:56
04:23
AlvaroFitbit
Hi,
I use bike or bus to go office , I observed that steps are getting added for this activity also, I tried to remove them from the overall steps based on the timing of commute, but I could not do it.
Any suggestions
05-03-2021
04:24
10:06
05-03-2021
04:24
10:06
@Naveen28 Thanks for joining us!
Thank you for trying to remove the steps counted while riding the bus. Your device will detect the movement on your arm and translate that movement into steps. There are situations in which your arm may move but you won't be actually walking. For example, this may happen when you are playing the drums, burping a baby or clapping. It can also happen while driving. You can negate these steps by logging a driving activity. You can try wearing your device on your non-dominant hand but select that hand as dominant on the device’s settings to make it less sensitive to movement.
Hope this helps.
