10-31-2021 04:27
10-31-2021 04:27
As the title suggests I've been through all the suggested fixes on this. I can get the app to recognise the device when its plugged in but it wont sync via bluetooth. I've tried using the app on Android, Ipad and my PC all fail at the same stage. Is there anything I can do? Can I reset the device? Many thanks for your help.
18:58
08:58
11-02-2021
18:58
08:58
@Herenes Nice to see you around . Thank you for your report and efforts.
Could you described what you already tried so that I don't ask you to repeat it?
In the meantime please check that the energy saving mode and the do not disturb option (mute) are switched off on the mobile device.
Also make sure that no other Bluetooth device is connected to the mobile phone or nearby. (Headphones, keyboards, etc.)
IMPORTANT: please allow the Fitbit app to run in the background.
Please follow these steps, some you have already done, but the order is important:
