Trying to change my step count
I am trying to change my step count however when I follow the instructions I get as far as Click Devices. The next step is "Under Daily Goal Progress, choose the goal you want to work toward". When I Click Devices and choose Inspire, which is the only device I have, there is no Daily Goal Progress. Has any one else had this issue?
1 REPLY 1
It sounds like you are talking about your daily step goal.  I don't know where you got those instructions, but it looks like they might have been for an older app version.
From How do I set or change my Fitbit goals?
  • Fitbit app
    1. Tap the Today tab
      , and tap your profile picture.
    2. Find the Goals section, and tap the goal you want to view or adjust. (activity)
    3. Tap the part of the goal you want to adjust, and follow the on-screen instructions to make your changes. (steps)
