Trying to figure out
I'm trying to see what kind I have and can't really figger it out will some one help me
3 REPLIES 3
Hi @Herronautumn  if you bought it, you should know what you have. If it was a gift, the giver would know. Don't you have the box it came in? When you try to add it to your phone, it will ask you if it's an Inspire or not.You try that yet?
Stepping in the U.S.A. since September 2013. Android 14
Hi @Herronautumn ,
Suppose the easiest way to see what you have is to scroll down on the tracker itself. If you can see a heart and it shows your heart rate, then you have the Inspire HR. If not then it is the Inspire.
Or as @Odyssey13 is saying, it should be on the box.
@Herronautumn  how are things going? When you try to set up the Fitbit, after downloading the app, you will be asked which device you're trying to set up. The choice you're given is usually the device that it recognizes from your bluetooth.
